DT Swiss 240 EXP Super Boost J-Bend Disc Rear Hub
$436.90
With the latest generation of the 240 hub, the strengths of DT Swiss' legendary hub have been further enhanced. The latest Ratchet EXP freehub system increases the bearing lifetime thanks to the increased bearing distance which also increases stiffness by a claimed 15%. Further machining has lightened the hub even more than the previous generation. The updated version of the end caps simplifies the tool-free disassembly and makes maintenance easier. The hollow-machined ratchets transfer the energy invested directly into acceleration thanks to the 36 teeth, can be upgraded to a 54t engagement.
WHEEL BUILDING
  6-Bolt
 Weight ~237g
 Axle Standard 12 x 157 mm
 Spoke Holes 28 / 32
 Bearing Size 1526 - (2)
 Freehub Engagement Ratchet EXP 36t
 Flange Diameter Left 56.7 mm
 Flange Diameter Right 49.9 mm
 Center to Left Flange 41.6 mm
 Center to Right Flange 27.1 mm
 Spoke Hole Diameter 2.55 mm
