DT Swiss 240 EXP Straight-Pull Disc Rear Hub
$465.90
Article number: 019-04-02
With the latest generation of the 240 hub, the strengths of DT Swiss' legendary hub have been further enhanced. The latest Ratchet EXP freehub system increases the bearing lifetime thanks to the increased bearing distance which also increases stiffness by a claimed 15%. Further machining has lightened the hub even more than the previous generation. The updated version of the end caps simplifies the tool-free disassembly and makes maintenance easier. The hollow-machined ratchets transfer the energy invested directly into acceleration thanks to the 36 teeth, can be upgraded to a 54t engagement.
WHEEL BUILDING
  Centerlock 6-Bolt
 Weight 24 28 28
 Spoke Holes ~192g ~196g ~215g
 Axle Standard 12 x 142 mm
 Bearing Size 1526 - (2) 1526 - (2)
  24 28 28
 Flange Diameter Left 37.3 36.9 35.9
 Flange Diameter Right 44.2 43.2 42.8
 Center to Left Flange 33.6 33.6 32.8
 Center to Right Flange 17.6 17.7 18.5
 Spoke Hole Offset L / R 1.4 / 0.4 2.0 / 0.4 0.45 / 1.5
 Spoke Hole Diameter 2.5 mm
