DT Swiss 240 EXP Straight-Pull Disc Front Hub
Article number: | 024-01-02 |
With the latest generation of the 240 hub, the strengths of DT Swiss' legendary hub have been further enhanced. The latest Ratchet EXP freehub system increases the bearing lifetime thanks to the increased bearing distance which also increases stiffness by a claimed 15%. Further machining has lightened the hub even more than the previous generation. The latest version of the end caps simplifies the tool-free disassembly and makes maintenance easier.
Covered by a 2 year warranty against manufacturing and material defects, 240 EXP hubs offer some of the best performance in the industry.
WHEEL BUILDING
24 hole | 28 hole | ||
Weight | ~104g | ~105g | ~114g |
Axle Standard | 12 x 100 | 15 x 100 | |
Brake Interface | Centerlock | Centerlock | 6-bolt |
Bearing Size | 1526 - (2) | 1728 - (2) | |
-- Wheel Building Dimensions -- | |||
Flange Diameter Left | 37.2 | 35.5 | |
Flange Diameter Right | 37 | 35.5 | |
Center to Left Flange | 22.1 | 21.6 | |
Center to Right Flange | 35.2 | 34.8 | |
Spoke Hole Offset L / R | 1.4 / 0.4 | 1.9 / 0.2 | |
Spoke Hole Diameter | 2.5 mm |
