DT Swiss 240 EXP Road Rear Rim Brake Hub
Article number: | 019-06-06 |
With the latest generation of the 240 hub, the strengths of DT Swiss' legendary hub have been further enhanced. The latest Ratchet EXP freehub system increases the bearing lifetime thanks to the increased bearing distance which also increases stiffness by a claimed 15%. Further machining has lightened the hub even more than the previous generation. The updated version of the end caps simplifies the tool-free disassembly and makes maintenance easier. The hollow-machined ratchets transfer the energy invested directly into acceleration thanks to the 36 teeth, can be upgraded to a 54t engagement.
WHEEL BUILDING
Straight-Pull | J-Bend | |
Weight | ~188 grams | ~202 grams |
Axle Standard | 5 mm x 130 mm | |
Spoke Holes | 24 | 24 / 28 |
Bearing Size | 1526 - (2) | |
Freehub Engagement | Ratchet EXP 36t | |
-- Wheel Building Dimensions -- | ||
Flange Diameter Left | 46.3mm | 37.2 mm |
Flange Diameter Right | 50.4 mm | 44.1 mm |
Center to Left Flange | 33.7 mm | 33.4 mm |
Center to Right Flange | 16.6 mm | 15.7 mm |
Spoke Hole Offset L / R | 1.8 / 0.4 | -- |
Spoke Hole Diameter | 2.5 | 2.4 |
