DT Swiss 240 EXP J-Bend Disc Rear Hub
$465.90
Article number: 024-01-01
With the latest generation of the 240 hub, the strengths of DT Swiss' legendary hub have been further enhanced. The latest Ratchet EXP freehub system increases the bearing lifetime thanks to the increased bearing distance which also increases stiffness by a claimed 15%. Further machining has lightened the hub even more than the previous generation. The updated version of the end caps simplifies the tool-free disassembly and makes maintenance easier. The hollow-machined ratchets transfer the energy invested directly into acceleration thanks to the 36 teeth, can be upgraded to a 54t engagement.
WHEEL BUILDING
  Centerlock 6-Bolt
 Weight ~221 grams ~233 grams
 Axle Standard 12 x 142 mm
 Spoke Holes 24 / 28
 Bearing Size 1526 - (2)
 Freehub Engagement Ratchet EXP 36t
 Flange Diameter Left 50.4 mm 57 mm
 Flange Diameter Right 50.4 mm 49.9 mm
 Center to Left Flange 34.3 mm 34.1 mm
 Center to Right Flange 19.6 mm 19.6 mm
 Spoke Hole Diameter 2.55 mm
