DT Swiss 240 EXP Boost Straight-Pull Disc Rear Hub
$436.90
With the latest generation of the 240 hub, the strengths of DT Swiss' legendary hub have been further enhanced. The latest Ratchet EXP freehub system increases the bearing lifetime thanks to the increased bearing distance which also increases stiffness by a claimed 15%. Further machining has lightened the hub even more than the previous generation. The updated version of the end caps simplifies the tool-free disassembly and makes maintenance easier. The hollow-machined ratchets transfer the energy invested directly into acceleration thanks to the 36 teeth, can be upgraded to a 54t engagement.
WHEEL BUILDING
  Centerlock 6-Bolt
 Weight ~207g ~215g
 Axle Standard 12 x 148 mm
 Spoke Holes 28
 Bearing Size 1526 - (2)
 Freehub Engagement Ratchet EXP 36t
 Flange Diameter Left 35.9 mm 35.9 mm
 Flange Diameter Right 42.8 mm 42.8 mm
 Center to Left Flange 32.8 mm 35.8 mm
 Center to Right Flange 18.5 mm 21.5 mm
 Spoke Hole Offset L / R 0.45 / 1.5 mm
 Spoke Hole Diameter 2.5 mm
