DT Swiss 240 EXP Boost Straight-Pull Disc Front Hub
$229.90
The DT Swiss 240s hub, known for its simplicity and durability, now aligns perfectly with wider Boost forks and frames. These hubs maintain dependability, add stiffness for better handling, especially on extreme terrain. Whether you ride 29” wheels or plus-size bikes, increased lateral stiffness enhances your experience. Easy servicing and parts replacement make these hubs ideal for riders who demand top performance. DT 240 EXP hubs ensure you keep rolling all season.
Covered by a 2 year warranty against manufacturing and material defects, 240 EXP hubs offer some of the best performance in the industry.
WHEEL BUILDING
  Centerlock 6-Bolt
 Weight ~110 grams ~118 grams
 Bearing Size Stainless - 1728 (2)
 Spoke Holes 28
 Axle Standard 15 x 110mm
--Wheel Building Dimensions--
 Flange Diameter Left 35.5 mm
 Flange Diameter Right 35.5 mm
 Center to Left Flange 26.5 mm
 Center to Right Flange 39.7 mm
 Spoke Hole Offset L / R 1.4 / 0.15 mm
 Spoke Hole Diameter 2.5 mm
