DT Swiss 240 EXP Boost Straight-Pull Disc Front Hub
The DT Swiss 240s hub, known for its simplicity and durability, now aligns perfectly with wider Boost forks and frames. These hubs maintain dependability, add stiffness for better handling, especially on extreme terrain. Whether you ride 29” wheels or plus-size bikes, increased lateral stiffness enhances your experience. Easy servicing and parts replacement make these hubs ideal for riders who demand top performance. DT 240 EXP hubs ensure you keep rolling all season.
Covered by a 2 year warranty against manufacturing and material defects, 240 EXP hubs offer some of the best performance in the industry.
WHEEL BUILDING
Centerlock | 6-Bolt | |
Weight | ~110 grams | ~118 grams |
Bearing Size | Stainless - 1728 (2) | |
Spoke Holes | 28 | |
Axle Standard | 15 x 110mm | |
--Wheel Building Dimensions-- | ||
Flange Diameter Left | 35.5 mm | |
Flange Diameter Right | 35.5 mm | |
Center to Left Flange | 26.5 mm | |
Center to Right Flange | 39.7 mm | |
Spoke Hole Offset L / R | 1.4 / 0.15 mm | |
Spoke Hole Diameter | 2.5 mm |
