DT Swiss 240 EXP Boost J-Bend Disc Front Hub
$229.90
The DT Swiss 240s hub, known for its simplicity and durability, now aligns perfectly with wider Boost forks and frames. These hubs maintain dependability, add stiffness for better handling, especially on extreme terrain. Whether you ride 29” wheels or plus-size bikes, increased lateral stiffness enhances your experience. Easy servicing and parts replacement make these hubs ideal for riders who demand top performance. DT 240 EXP hubs ensure you keep rolling all season.
Covered by a 2 year warranty against manufacturing and material defects, 240 EXP hubs offer some of the best performance in the industry.
WHEEL BUILDING
  Centerlock 6-Bolt
 Weight ~120 grams ~143 grams
 Bearing Size Stainless 1728 (2)
 Spoke Holes 28 / 32
 Axle Standard 15 x 110mm
--Wheel Building Dimensions--
 Flange Diameter Left 44.4 mm 57.8 mm
 Flange Diameter Right 44.4 mm 49.4 mm
 Center to Left Flange 27.6 mm 27.3 mm
 Center to Right Flange 41.2 mm 41 mm
 Spoke Hole Diameter 2.55 mm
