DT Swiss 180 EXP Road Rim Brake Front Hub
$383.90
The latest 180 hub generation enhances DT Swiss' top-of-the-line hub. Ratchet EXP system boosts bearing lifetime, stiffness by 15%, and energy transfer with 36 teeth. Tool-free disassembly and lightweight design make maintenance a breeze. Paired with SINC ceramic bearings, these hubs offer unparalleled performance.
WHEEL BUILDING
  Compare
  180 240
 Weight ~87g ~107g
 Spoke Holes 20h 20h
 Axle Standard 5 x 100 mm 5 x 100 mm
 Bearing Size Ceramic 6802 - (2) 1526 - (2)
 Brake Interface Rim Brake Rim Brake
--Wheel Building Dimensions--
 Flange Diameter Left 28.3 mm
 Flange Diameter Right 28.3 mm
 Center to Right Flange 38.4 mm
 Center to Left Flange 38.4 mm
 Spoke Hole Diameter 2.5 mm
