DT Swiss 180 EXP Straight-Pull Disc Front Hub
$383.90
Article number: 023-04-02
The latest 180 hub generation enhances DT Swiss' top-of-the-line hub. Ratchet EXP system boosts bearing lifetime, stiffness by 15%, and energy transfer with 36 teeth. Tool-free disassembly and lightweight design make maintenance a breeze. Paired with SINC ceramic bearings, these hubs offer unparalleled performance.
WHEEL BUILDING
  Compare
  24 hole 28 hole 240
 Weight ~92g ~98g ~105g
 Axle Standard 12 x 100 mm 12 x 100 mm
 Bearing Size Ceramic 6802 - (2) 1526 - (2)
 Brake Interface Centerlock Centerlock
--Wheel Building Dimensions--
  24 hole 28 hole
 Flange Diameter Left 35.7 mm 35.2 mm
 Flange Diameter Right 35.1 mm 34.6 mm
 Center to Left Flange 21.8 mm 21.5 mm
 Center to Right Flange 35.1 mm 34.7 mm
 Spoke Hole Offset L / R 1.5 mm / 1.75 mm 2.1 mm / 1.9 mm
 Spoke Hole Diameter 2.5 mm
