DT Swiss 180 EXP Road Rim Brake Rear Hub
Article number: | 023-04-02 |
The latest 180 hub generation enhances DT Swiss' top-of-the-line hub. Ratchet EXP system boosts bearing lifetime, stiffness by 15%, and energy transfer with 36 teeth. Tool-free disassembly and lightweight design make maintenance a breeze. Paired with SINC ceramic bearings, these hubs offer unparalleled performance. The hollow-machined ratchets transfer the invested energy directly into acceleration, thanks to the 36 teeth. You have the option to upgrade to a 54-tooth engagement here for improved performance.
WHEEL BUILDING
Compare | ||
180 | 240 | |
Weight | ~182g | ~232g |
Spoke Holes | 24h | 24h |
Axle Standard | 5 x 130 mm | 5 x 130 mm |
Bearing Size | Ceramic 6802 / 1526 | 1526 - (2) |
Brake Interface | Rim Brake | Rim Brake |
Bearing Size | Ratchet EXP 36t |
--Wheel Building Dimensions-- | |
Flange Diameter Left | 35.7 mm |
Flange Diameter Right | 42.3 mm |
Center to Right Flange | 33.3 mm |
Center to Left Flange | 15.4 mm |
Spoke Hole Offset L / R | 1.4 mm / 0.0 mm |
Spoke Hole Diameter | 2.5 mm |
