DT Swiss 180 EXP Straight-Pull Disc Rear Hub
Article number: | 023-04-02 |
The latest 180 hub generation enhances DT Swiss' top-of-the-line hub. Ratchet EXP system boosts bearing lifetime, stiffness by 15%, and energy transfer with 36 teeth. Tool-free disassembly and lightweight design make maintenance a breeze. Paired with SINC ceramic bearings, these hubs offer unparalleled performance. The hollow-machined ratchets transfer the invested energy directly into acceleration, thanks to the 36 teeth. You have the option to upgrade to a 54-tooth engagement here for improved performance.
WHEEL BUILDING
Compare | ||||
180 | 240 | |||
24 hole | 28 hole | 24 hole | 28 hole | |
Weight | ~187g | ~190g | ~192g | ~196g |
Spoke Holes | 24h / 28h | 24h / 28h | ||
Bearings Size | Ceramic 6802 / 1526 | Stainless | ||
Axle Standard | T/A 12 x 100 | T/A 12 x 100 | ||
Brake Interface | Centerlock | Centerlock | ||
Freehub Engagement | Ratchet EXP 36t | Ratchet EXP 36t |
-- Wheel Building Dimensions -- | ||
Flange Diameter Left | 35.7 mm | 35.4 mm |
Flange Diameter Right | 42.3 mm | 41.8 mm |
Center to Left Flange | 33.4 mm | 33.4 mm |
Center to Right Flange | 17.3 mm | 17.5 mm |
Spoke Hole Offset L / R | 1.4 mm / 0.2 mm | 2.0 mm / 0.4 mm |
Spoke Hole Diametere | 2.5 mm |
