DT Swiss 180 EXP Boost Disc Front Hub
Article number: | 019-05-02 |
The latest 180 hub generation enhances DT Swiss' top-of-the-line hub. Ratchet EXP system boosts bearing lifetime, stiffness by 15%, and energy transfer with 36 teeth. Tool-free disassembly and lightweight design make maintenance a breeze. Paired with SINC ceramic bearings, these hubs offer unparalleled performance.
WHEEL BUILDING
Compare | Compare | |
180 | 240 | |
Weight | ~95g | ~110g / 118g |
Spoke Holes | 28h | 28h |
Axle Standard | T/A 15 x 110 | T/A 15 x 110 |
Bearing Size | Ceramic 6803 - (2) | 1728 - (2) |
Brake Interface | Centerlock | Centerlock / 6-bolt |
--Wheel Building Dimensions-- | ||
LEFT | RIGHT | |
Flange Diameter | 34.5 mm | 34 mm |
Center to Flange | 26.4 mm | 39.8 mm |
Spoke Hole Offset | 1.05 mm | 0.1 mm |
Spoke Hole Diameter | 2.5 mm |
