DT Swiss 180 EXP Boost Disc Rear Hub
$714.90
Article number: 023-04-02
The latest 180 hub generation enhances DT Swiss' top-of-the-line hub. Ratchet EXP system boosts bearing lifetime, stiffness by 15%, and energy transfer with 36 teeth. Tool-free disassembly and lightweight design make maintenance a breeze. Paired with SINC ceramic bearings, these hubs offer unparalleled performance. The hollow-machined ratchets transfer the invested energy directly into acceleration, thanks to the 36 teeth. You have the option to upgrade to a 54-tooth engagement here for improved performance.
WHEEL BUILDING
  Compare
  180 240
 Weight ~185g ~207g
 Spoke Holes 28h  28h
 Bearings Size Ceramic 6802 / 1526 1526 - (2)
 Axle Standard T/A 12 x 148 mm T/A 12 x 148 mm
 Brake Interface Centerlock Centerlock
 Freehub Engagement Ratchet EXP 36t Ratchet EXP 36t
 Flange Diameter Left 34.5 mm
 Flange Diameter Right 41.3 mm
 Center to Left Flange 35.7 mm
 Center to Right Flange 21.5 mm
 Spoke Hole Offset L / R 0.45 mm / 1.5 mm
 Spoke Hole Diameter 2.5 mm
