Cybrei Direct Mount Crank Spider
$34.00
With its sleek aluminum construction, the Cybrei Direct Mount Spider is a key component in transferring power from the crank arms to the chainrings in Cybrei's high-performance cranks. Expertly CNC-machined from durable yet lightweight AL7075 aluminum alloy, the Spider tips the scales at a feathery 40g while remaining stiff and unyielding under the strains of all-out sprints or lung-busting climbs. Specifically designed for seamless compatibility with Cybrei's proprietary crank arm interface, this product can also be used with other CINCH style crank arms.
 Weight ~40g
 Material CNC AL7075 Aluminum
 Bolt Circle Diameter 4-bolt x 110 mm BCD
 Crank Interface Easton CINCH Direct Mount
 Finish Anodized Black
