Cybrei Carbon Direct Mount Crankset
With the CYBREI carbon fiber crank, every detail has been engineered for performance and weight savings. Extensive testing with professional cyclists has refined the design to achieve an optimal balance of featherweight portability and unmatched stiffness. The intricate T1000 carbon layup and innovative dual-airway EPS internal molding yield a crank that tips the scales at just 320g while still delivering over 101.5 N/mm of rigidity. Paired with your choice of chainring interface, available arm lengths from 162.5-175mm, and compatibility with all major bottom bracket standards, this crank offers exceptional versatility to find your perfect fit and function.
Crankarms | 162.5 / 165 / 167.5 / 170 / 172.5 / 175 |
Weight | ~320g (170mm) |
Q-Factor | 148mm |
Chainline | 44.5mm |
Bottom Bracket | Stainless - Praxis / Ceramic |
Interface/BCD | Easton CINCH style Direct Mount |
