ControlTech Tux Compact Carbon Handlebar
$210.00
Whether ascending or powering on flats, the Controltech Tux carbon compact road bar utilizes unidirectional carbon fiber construction to maximize your energy output. The impressive strength-to-weight ratio of the UD carbon fiber allows the bars to remain lightweight and stiff while still providing the dampening qualities for an incredibly comfortable ride. With the compact drop, these bars are perfect for both smaller riders and those who prefer a higher position in the drops.  The Controltech "Half Moon Shape” (HMS) bars have an outward bend of 4 degrees and provide a multi-contact drop that delivers an array of hand positions.  These bars are drilled out on the underside of the drops to allow internal routing for Shimano's newer bar-end Di2 junction A box as well as having external groves for all other cable routing.  Available in 40cm (161 grams), 42cm (168 grams), and 44cm (172 grams) widths with a 125mm drop, 75mm reach, and 31.8mm clamp diameter.
Weight (40 cm)161 grams
Weight (42 cm)168 grams
Weight (44 cm)172 grams
Stem Clamp Diameter31.8 mm
Reach75 mm
Drop125 mm
Outward Bend4 degrees
MaterialUD Carbon
Internal routing compatibleNo
Di2 compatibleYes (ports for bar plug style junction A box)
Road Handlebars
UD Matte
Size:
40cm
Size:
42cm
Size:
44cm
Style:
Road
Diameter:
31.8mm
Carbon
