ControlTech TiMania Titanium Stem
$265.00
Well known for their work in aluminum and carbon fiber, ControlTech has made a name for themselves by making an array of quality parts suitable for nearly every build. That being said, some of their more recent, truly impressive componentry has been painstakingly constructed from titanium; yielding fantastic results. The TiMania stem is the representation of thoughtful construction and in depth knowledge of the material being used. In this case ControlTech opted for 6AL/4V titanium alloy in an attempt to capture ideal material stiffness while retaining the natural vibration dampening benefits of ti.
What really sets the TiMania stem apart from lesser titanium stems is it’s unique method of construction. By utilizing cold forging, ControlTech is able to produce a seamless stem. This process provides much finer metallurgical control over each piece. Essentially, ControlTech is able to align the grain structure of the stem to suit ideal riding characteristics as well as strength and durability. Surprisingly, the TiMania stem proves to be as stiff as other well known alloy stems while still eating many road or trail vibrations. Perfect for the cyclist looking for the finishing touch on their next ti build, the TiMania stem comes complete with 6Al/4V titanium hardware as well as a handsomely minimalist ti faceplate.
It is highly recommended that your ControlTech TiMania Stem be installed by a competent mechanic using a torque wrench set to a maximum of 6 Nm. Be sure to properly clean the stem / handlebar interface, as well as use the appropriate titanium specific grease when installing the TiMania stem. For the ideal uniform aesthetic, couple your ControlTech TiMania stem with the TiMania road handlebar, mountain handlebar, seatpost, and headset spacers.
Material6AL/4V titanium
Bar Clamp Diameter31.8 mm
Steerer Clamp Diameter28.6 mm
Stack Height40 mm
Max Torque6 Nm
Angle+/- 5°
Weights
70 mm101 grams
90 mm116 grams
100 mm124 grams
110 mm132 grams
120 mm142 grams
Stems
Silver
Titanium
Size:
90mm
Size:
100mm
Size:
110mm
Size:
120mm
Style:
Road
Style:
Mountain
Diameter:
31.8mm
Titanium
