ControlTech TiMania Flat Handlebar
$150.00
Controltech is responsible for making some exceedingly beautiful titanium components for many different applications on the bike, with the TiMania flat handlebar being no exception. It’s beauty is subtle, but its attention to detail is what makes it a work of art. The perfect choice for those who desire the look and feel of titanium for their next build, the TiMania flat handlebar is constructed from 100% titanium alloy, and is robust enough to handle daily abuse from even the strongest riders. Couple the supple ride of titanium with the elegant bend and sweep of the TiMania flat bar, and you’ve got an ideal bar suited for many different MTB applications.
We highly recommend that your ControlTech TiMania flat Handlebar be installed by a competent mechanic using a torque wrench set to a maximum of 6 Nm. Please be sure to properly clean the stem and handlebar interface prior to installation, and always use the appropriate grease on all bolts. For the Ideal titanium aesthetic, pair your ControlTech flat handlebar with the TiMania seatpost, stem and headset spacers.
Materialtitanium
Stem Clamp Diameter31.8 mm
Back Sweep660 mm : 5°
720 mm : 9°
Weights
660 mm225 grams
720 mm279 grams
Mountain Handlebars
Titanium
Silver
Size:
660mm
Size:
720mm
Style:
Mountain
Diameter:
31.8mm
Titanium
