ControlTech Newton Stem
$65.00
ControlTech's Newton stem is an understated piece that performs its function to near perfection, leaving nothing wanting and nothing wasted. Middle weight, medium priced stems such as this can be found in countless iterations. The Newton Silver sets itself apart from the modern crowd with a classic look - an attractive, polished and clear-anodized surface adorned with minimalist printed graphics. The T6-tempered 7075 aluminum material promises superior strength, while both the steerer and handlebar clamp surfaces offer ample surface area for superior grip. The Newton is fitted with stainless steel hardware to inspire maximum confidence.
Material7075 T6 aluminum
Hardwarestainless steel
Rise+/- 5°
Stack38 mm
Steerer Clamp28.6 mm (1-1/8")
Handlebar Clamp31..8 mm
Max Steerer Torque10 Nm
Max Bar Torque8 Nm
Weights
90 mm148 grams
100 mm157 grams
110 mm167 grams
Stems
Silver
Size:
90mm
Size:
100mm
Size:
110mm
Style:
Road
Style:
Mountain
Diameter:
31.8mm
Aluminum
