$49.50
* Unit price: $49.50 /
Article number: ATB-956-40
With an eye towards aggressive trail riding, ControlTech's Lynx stem provides maximum control and durability in a short, stout package. Crafted from lightweight yet robust 6061 aluminum alloy, this stem delivers precise steering and rock-solid stability when the trail gets rowdy. Its clean lines and subtle graphics add style without sacrificing strength. Whether you're sending big hits or rallying technical singletrack, the Lynx stem gives you the performance and confidence needed to push your limits on the mountain.
Length 40 mm 50 mm
Weight ~139g ~155g
Stem Angle
Stack 40.8 mm
Clamp Diameter 31.8 mm
Steerer Diameter 1 - 1/8" (1.125mm)
Max Torque 6Nm
Recommended Use All Mountain / Enduro
Material Stem Hardware
  6061 Aluminum Stainless Steel
