ControlTech Falcon Stem
$46.00
With their sleek black finish, ControlTech's unassuming Falcon series of components may not immediately stand out of the ever-growing crowd of black bicycle components. However, a closer look will reveal an attractive, yet functional, aerodynamic design. The Falcon 6061 aluminum stem uses an advanced 3D-forged and CNC-machined production process to form a stem with clean smooth lines, a low stack height, and a super cool integrated top cap. The Falcon stem is available in four lengths, and is designed to be installed with either positive or negative five degree rise, with inverted logos and an integrated top cap cutout on either side. And, best of all, ControlTech offers this stem with a respectable weight and a reasonable price tag.
The Falcon stem's integrated top cap is designed to be installed with the top of the steerer tube cut below the top of the stem clamp by 1-3mm. Additionally, most bicycles will require at least a 3mm headset spacer under the stem. Please note that this stem has a lower stack height than most other stems, and you may experience fitment issues when changing your stem.
Material6061 aluminum
Hardwarestainless steel, black
Stem Angle+/-5°
Clamp Diameter31.8 mm
Steerer Clamp Diameter1-1/8"
Stack30.1 mm
Max Torque6 Nm
Recommended UseRoad, Cyclocross, XC
Weights
90 mm138 grams
100 mm150 grams
110 mm158 grams
120 mm159 grams
Stems
Size:
90mm
Size:
100mm
Size:
110mm
Size:
120mm
Style:
Road
Style:
Mountain
Diameter:
31.8mm
Aluminum
