ControlTech Falcon Stem
$47.00
* Unit price: $47.00 /
Discover ControlTech's Falcon series—where timeless style meets lasting performance. With a sleek black finish, these components seamlessly blend into any bike setup. Crafted from 6061 aluminum, the Falcon stem boasts a sleek design with a low stack height and integrated top cap. Available in various lengths and adaptable to different riding styles, it offers versatility without compromise. With inverted logos and precise engineering, each detail reflects ControlTech's dedication to excellence.
The Falcon stem's integrated top cap requires the steerer tube to be cut 1-3mm below the stem clamp. Add at least a 3mm spacer under the stem. This stem has a lower stack height than most, so you may need to adjust your fit when installing.
Length 90 mm 100 mm 110 mm 120 mm
Weight ~138g ~146g ~154g ~159g
Stem Angle ± 5°
Stack 30.1 mm
Clamp Diameter 31.8 mm
Steerer Diameter 1 - 1/8" (1.125mm)
Max Torque 6Nm
Recommended Use Road / Cyclocross
Material Stem Hardware
  6061 Aluminum Stainless Steel
