ControlTech EXL Gravel Carbon Handlebar
$196.00
Controltech's EXL Gravel Carbon Handlebar delivers when considering some of the most important aspects of a lightweight gravel/adventure drop bar set-up: weight, vibration damping, stiffness, and hand position options.  With its unidirectional carbon fiber construction these bars save precious grams over other materials, while being stronger and stiffer than woven carbon fiber.  While this strength and stiffness maximizes energy output, the UD carbon also has dampening characteristics that result in a more comfortable ride.  Aside from the material characteristics, Controltech designed these bars to be comfortable for a multitude of hand positions and hand sizes.  To handle rougher terrain, the bars feature a unique triangular cross section that improves grip, control, and handling while the drops sweep out to create a wider, more stable platform.   One of the few gravel bars currently compatible with Shimano's new Di2 junction box, the EXL Gravel Bar is drilled out for internally wiring the bar end junction.  The bars weight 230 grams, feature a 145mm drop, 75mm reach, a 31.8mm bar diameter, and are available in 400mm, 420mm, and 440mm lengths.
Weight (40 cm)230 grams
Weight (42 cm)233 grams
Weight (44 cm)237 grams
Stem Clamp Diameter31.8 mm
Reach75 mm
Drop145 mm
Back Sweep6 degrees
Outward Bend16 degrees
MaterialUD Carbon
Internal routing compatibleNo
Di2 compatibleYes (ports for bar plug style junction A box)
Road Handlebars
UD Gloss
Size:
40cm
Size:
42cm
Size:
44cm
Style:
Road
Style:
Gravel/CX
Diameter:
31.8mm
Carbon
