ControlTech EXL Gravel Carbon Handlebar
$270.00
* Unit price: $270.00 /
Article number: 8611
Controltech's carbon EXL Gravel Handlebar brings performance and versatility to off-road riding. Its unique triangular cross-section improves grip and control when terrain gets rough, while the 16 degree flare creates a wider platform for added stability. The 6 degree backsweep allows for a more comfortable hand position over long distances. Compatible with Shimano's Di2 junction box, the EXL Gravel Bar enables clean electronic shifting and can be internally wired for a clutter-free cockpit. Weighing in at just 214-227g depending on width, this lightweight handlebar damps vibration while remaining stiff for optimal power transfer. For discerning riders seeking comfort, control, and clean aesthetics, the EXL Gravel Bar delivers.
  40 cm 42 cm 44 cm
 Weight ~214g ~220g ~227g
 Reach 65 mm
 Drop 145 mm
 Flare 16°
 Back Sweep
 Stem Clamp Diameter 31.8 mm
 Material UD Carbon
 Internal Routing No
 Di2 Compatible Yes (ports for junction A box)
