ControlTech Cougar Carbon Road Handlebar
$220.00
Controltech's Cougar carbon handlebar combines aerodynamics and comfort in a lightweight package.  The strength-to-weight ratio of carbon fiber makes it ideal for the construction of the bars, achieving a strong and stable platform while remaining lightweight.  Flared bar tops improve aerodynamics, while the triangular design of the drops improves comfort, control, and tactility.
The bars feature a 31.8mm clamp diameter, 125mm drop, 78mm reach, and are available in 40cm, 42cm, and 44cm widths.  Drill-outs provide internal routing options for brake and shift housing as well as compatibility with Shimano's bar end Di2 junction box (EW-RS910).  Weights range from 229 grams to 239 grams depending on bar width.
Weight (40 cm)229 grams
Weight (42 cm)238 grams
Weight (44 cm)239 grams
Stem Clamp Diameter31.8 mm
Reach78 mm
Drop125 mm
MaterialCarbon
Internal routing compatibleYes
Di2 compatibleYes
