No flowery description needed here.
GP 5000 TL (tubeless) Specifications | |
Weight, 700x25 | 300 grams (claimed) |
Weight, 700x28 | 340 grams (claimed) |
Weight, 700x32 | 380 grams (claimed) |
Rim Compatibility | 700 c |
Rim Type | tubeless (can be set up with a tube on either clincher or tubeless rims) |
Recommended Tire Pressure Range (700 x 25) | 80-109 PSI |
Recommended Tire Pressure Range (700 x 28) | 65-94 PSI |
Recommended Tire Pressure Range (700 x 32) | 65-87 PSI |
Casing Thread Count | 180 TPI |
Technologies | Vectran Breaker |
GP 5000 (non-tubeless) Specifications | |
Weight, 700x25 | 220 grams (claimed) |
Weight, 700x28 | 250 grams (claimed) |
Rim Type | clincher (can be set up with a tube on either clincher or tubeless rims) |
Recommended Tire Pressure Range (700 x 25) | 95-120 PSI |
Recommended Tire Pressure Range (700 x 28) | 95-115 PSI |
Casing Thread Count | 330 TPI |
