Italian parts manufacturer, Carbon-Ti has be carving a name for themselves over the past few years as designers of components fit for the most elite builds. As an offshoot of parent company LLS Titanium, Carbon-Ti is born with years of material science and engineering experience, ensuring that each of their products is thoughtfully crafted with durability in mind.
The semi-floating X-Rotor from Carbon-Ti is perhaps one of the most beautifully exotic rotors we have ever seen. By using a unique blend of carbon fiber, titanium, and steel, the X-Rotor is able to seamlessly blend weight savings and aesthetics into one utilitarian package. Compatible with any pad, the stainless steel braking surface has been specially designed to extend pad wear life, while guaranteeing optimum braking power and heat management. By utilizing titanium rivets, as well as a carbon fiber carrier, Carbon-Ti is able to shave as many grams as possible, while still making a structurally sound semi floating rotor capable of withstanding the abuse of mountain trails.
The Carbon-Ti X-Rotor is proudly made in Italy.
Pad Compatibility | Organic Metallic |
Weights | |
140mm | 67 grams |
160mm | 78 grams |
Materials | |
Carrier | carbon fiber |
rivets | titanium |
Rotor | stainless steel |
Product Manual | |
X-Rotor Manual |
