Responsible for some impressively lightweight components, Italian parts manufacturer Carbon-Ti is a name every cyclist ought to know. Born from Italian special alloy and carbon fiber manufacturer, LLS Titanium, Carbon-Ti is able to draw on years of experience in material science and design in order to create some truly ingenious parts. Through extensive machining and impressive anodization, Carbon-Ti is able to create a unique aesthetic that adds a dash of flair to any build.
With the industry quickly turning more and more to the use of thru axle designs on many frames and forks, having options for tuning your build with quality aftermarket components becomes increasingly important. For those looking to shed grams while simultaneously maintaining an impressive minimalist look, the 12 mm X-Lock is an ideal choice. Available in a plethora of standards, the X-Lock is a performance part sure to find a home on most modern mountain bikes.
The X-Lock 12mm rear thru axle is proudly manufactured in Italy.
Check out our blog for better info about which thru axle to use | ||||||
E-Thru | Hub Compatibility | Interface | Length | Thread Pitch | Thread Length | Weight |
E-Thru | TA 12 x 142 | Flat | 171mm | 12 x 1.5 mm | 17mm | 32g |
Road | TA 12 x 142 | Flat | 166mm | 12 x 1.5 mm | 18mm | 31g |
Boost | TA 12 x 148 Boost | Flat | 178mm | 12 x 1.5 mm | 18mm | 33g |
Maxle | Hub Compatibility | Interface | Length | Thread Pitch | Thread Length | Weight |
Maxle | TA 12 x 142 | Flat | 174mm | 12 x 1.75 mm | 20mm | 33g |
135 | TA 12 x 135 | Flat | 167mm | 12 x 1.75 mm | 20mm | 32g |
150 | TA 12 x 150 | Flat | 182mm | 12 x 1.75 mm | 20mm | 34g |
ABP | TA 12 x 142 | Flat | 192mm | 12 x 1.75 mm | 20mm | 35g |
ABP Boost | TA 12 x 148 Boost | Flat | 198mm | 12 x 1.75 mm | 20mm | 36g |
Scott / X-12 | Hub Compatibility | Interface | Length | Thread Pitch | Thread Length | Weight |
Scott | TA 12 x 142 | Flat | 168mm | 12 x 1.0 mm | 16mm | 32g |
Road | TA 12 x 142 | Flat | 158mm | 12 x 1.5 mm | 13mm | 30g |
X-12 | TA 12 x 142 | Tapered | 159mm | 12 x 1.0 mm | 16.5mm | 34g |
Boost | TA 12 x 148 Boost | Tapered | 166mm | 12 x 1.0 mm | 17.5mm | 34g |
Material | 7075 aluminum | |||||
Tool Fitting | 5m Hex | |||||
Recommended Torque | Max 10 Nm |
