Carbon-Ti X-Lock Rear Thru Axle
$85.00
$72.25
* Unit price: $72.25 /
Article number: 008-04-05
With the industry quickly turning more and more to the use of thru axle designs on many frames and forks, having options for tuning your build with quality aftermarket components becomes increasingly important. For those looking to shed grams while simultaneously maintaining an impressive minimalist look, the 12 mm X-Lock is an ideal choice. Available in a plethora of standards, the X-Lock is a performance part sure to find a home on most modern mountain bikes.
The X-Lock 12mm rear thru axle is proudly manufactured in Italy.
 Material 7075 Aluminum
 Tool Fitting 5m Hex
 Recommended Torque Max 10 Nm
 E-Thru Length Compatibility Thread Weight
 E-Thru 171mm 12 x 142 mm 17mm ~32g
 Road (EVO) 166mm 12 x 142 mm 18mm ~31g
 Boost 178mm 12 x 148 mm 18mm ~33g
 Pitch 12 x 1.5 mm
 Interface Flat
 Maxle 174 mm 12 x 142 mm 20 mm ~33g
 135 mm 167 mm 12 x 135 mm 20 mm ~32g
 150 mm 182 mm 12 x 150 mm 20 mm ~34g
 ABP 192 mm 12 x 142 mm 20 mm ~35g
 ABP Boost 198 mm 12 x 148 mm 20 mm ~36g
 Pitch 12 x 1.75 mm
 Interface Flat
 Scott / X-12 Interface Length Compatibility Thread Weight
 Scott Flat 168 mm 12 x 142 mm 16 mm ~32g
 Road Flat 158 mm 12 x 142 mm 16.5 mm ~34g
 X-12 (EVO) Tapered 159 mm 12 x 142 mm 16.5mm ~34g
 Boost Tapered 166 mm 12 x 148 mm 17.5 mm ~34g
 Pitch 12 x 1.0
