Carbon-Ti X-Lock EVO Rear X-12 / 12x1.0 Thru Axle
Article number: | 008-02-02 |
True to the quality we have come to expect from Carbon-Ti, these thru axles are excellently stiff, with variable thickness. There is a 6mm hex fitting for safe and secure closing(hex key not provided), as well as beautifully laser etched graphics.
These axles are available in several of Carbon-Ti's beautiful anodized hues.
All Carbon-Ti products are proudly designed and manufactured in Italy.
T/A 12 x 1.0 | Interface | Axle Standard | Pitch | Thread Length | Weight |
159 mm | Tapered | X-12 / Syntace | 12 x 1.0 mm | 16.5 mm | ~30g |
166 mm* | Tapered | X-12 / Syntace Boost* | 12 x 1.0 mm | 17.5 mm | ~32g |
168 mm | Flat | T/A 12 x 142-148 | 12 x 1.0 mm | 16 mm | ~31g |
171.5 mm* | Flat | T/A 12 x 148* | 12 x 1.0 mm | 9 mm | ~32g |
174 mm* | Flat | T/A 12 x 148* | 12 x 1.0 mm | 15 mm | ~31g |
178.5 mm* | Flat | T/A 12 x 148* | 12 x 1.0 mm | 15 mm | ~32g |
Material | 7075 Aluminum | ||||
Tool Fitting | 6 mm Hex | ||||
Hub Compatibility | T/A 12 x 142 | T/A 12 x 148* | ||||
Recommended Torque | 10Nm |
Frames Compatibility List:
X-Lock X-12 (159 mm)
- Cannondale
- Scalpel 29er (2013-2015)
- Canyon
- Lux CF (2014-2015)
- Gran Canyon CF (2014-2015)
- Specialized
- S-Works
- Aethos (2021)
- Tarmac SL7, SL6 Disc (2019-2021)
- Crux (2019-2021)
- Venge Disc (2019-2020)
- Epic (2011-2017)
- Stumpjumper HT (2015-2016)
- Tarmac SL7, SL6 (Pro, Expert, Comp) Disc (2019-2020)
- S-Works
X-Lock X-12 (166 mm)
- BMC
- Fourstroke 01 (2019-2021)
- Twostroke 01 (2019-2021)
- Radon
- Jealous (2018)
- Specialized
- S-Works Epic (2018-2021)
- Epic (2018-2021)
- S-Works Epic HT (2017-2021)
- Epic HT (2017-2021)
X-Lock 12x1.0 (168 mm)
- Lynskey
- Pro 29 (2015)
- Santa Cruz
- 5010 V1, V2, V3
- Bantam V1
- Blur (LT V2.1c V2.2), (TR V1.1), (XC V2.2)
- Bronson V1, V2, V3
- Chameleon V5, V6, V7
- Heckler V7
- Highball V1, V2, V3
- High Tower (V1 and V2), (LT V1)
- Tallboy LT V1.1
- Mega Tower V1
- Tallboy V1.1, V2, V3, V4
- Scott
- Spark 700 & 900 (2014-2015)
- Scale 700 & 900 (2014-2015)
X-Lock 12x1.0 (171.5 mm)
- Scott
- Spark Boost / RC Boost (2017)
- Scale Boost / RC Boost (2017)
- Ransom 900 Tuned (2019)
X-Lock 12x1.0 (174 mm)
- KTM
- Myroon Master (UDH Interface) (2022)
- Trek
- Supercaliber (UDH Interface) (2022)
- Procaliber (UDH Interface) (2022)
X-Lock 12x1.0 (178.5 mm)
- ARC8
- Evolve FS
- Scott
- Spark (UDH Interface)
- Wilier
- Urta SRL (UDH Interface)
_____________________: | _____________________ |
Material: | • 7075 Aluminum |
Hub Compatibility: | • T/A 12 x 142 | T/A 12 x 148 |
Tool Fitting: | • |
