Carbon-Ti X-Lock EVO Rear E-Thru Thru Axle
Article number: | 008-02-03 |
True to the quality we have come to expect from Carbon-Ti, these thru axles are excellently stiff, with variable thickness. There is a 6mm hex fitting for safe and secure closing(hex key not provided), as well as beautifully laser etched graphics.
These axles are available in several of Carbon-Ti's beautiful anodized hues.
All Carbon-Ti products are proudly designed and manufactured in Italy.
E-Thru | Interface | Axle Standard | Pitch | Thread Length | Weight |
158 mm | Flat | Scott Road | 12 x 1.5 mm | 13.5 mm | ~30g |
166 mm | Flat | Shimano Road | 12 x 1.5 mm | 17 mm | ~31g |
168.7 mm | Flat | Shimano Road | 12 x 1.5 mm | 17 mm | ~32g |
172 mm | Flat | Shimano Road | 12 x 1.5 mm | 17 mm | ~32g |
178 mm* | Flat | Shimano Boost* | 12 x 1.5 mm | 17 mm | ~34g |
Material | 7075 aluminum | ||||
Tool Fitting | 6 mm Hex | ||||
Hub Compatibility | T/A 12 x 142 | T/A 12 x 148* | ||||
Recommended Torque | 10Nm |
Compatibility List:
X-Lock X-E-Thru (158 mm)
- Scott
- Foil Disc (2019)
- Addict Gravel (2019-2021)
X-Lock X-E-Thru (166 mm)
- Bianchi
- Oltre XR4 Disc (2019)
- Specialissima Disc (2021)
- Zolder Pro (2019)
- Cinelli
- Pressure (2021)
- Pinarello
- Prince Disc (2019)
- Tred
- Arachnide Titanio (2019)
- Ridley
- Noah
X-Lock X-E-Thru (168.7 mm)
- Scott
- Addict (2020-2021)
X-Lock X-E-Thru (172mm)
- BMC
- FourStroke FS01 (2013-2015)
- FourStroke FS02 (2013)
- Cinelli
- Nemo Tig Gravel (2021)
- Focus
- SuperBud 29r (2014)
- Giant
- Anthem Advanced 27.5 (2015)
- XtC Advanced 27.5 (2014-2015)
- GT
- Zaskar 100 (2013)
- Haibike
- Greed (2012)
- Kona
- King Kahuna 29er (2003)
- Lapierre
- Zesty (2014)
- Spicy (2014)
- Titici
- Explosion (2013-2015)
- Flexy (2014-2015)
- Rocky Mountain
- Element 950 RSL 29" (2014)
- Vertex Carbon 29" (2012)
- Yeti
- SB6 Carbon (2015-2016)
- SB4.5C Boost 148 (2016)
- SB5.5C Boost 148 (2016)
X-Lock X-E-Thru Boost(122mm)
- Bianchi
- Methanol Disc (2019-2021)
- Pivot
- Firebird 27.5 (2019-2021)
- Merida
- Big Nine Boost
