Carbon-Ti X-Lock EVO 15 mm Front Thru Axle
$79.00
Article number: 009-05-01
True to the quality we have come to expect from Carbon-Ti, these thru axles are excellently stiff, with variable thickness. There is a 6mm hex fitting for safe and secure closing(hex key not provided), as well as beautifully laser etched graphics.
These axles are available in several of Carbon-Ti's beautiful anodized hues.
All Carbon-Ti products are proudly designed and manufactured in Italy.
Model Interface Length Pitch Thread Length Weight
RockShox (148 mm) Flat 148 mm 15 x 1.5 mm 11.5 mm ~33g
Fox Boost (155 mm) Flat 155 mm 14 x 1.5 mm 13 mm ~34.5g
RockShox Boost (158 mm) Flat 158 mm 15 x 1.5 mm 11.5 mm ~34.5g
 Material 7075 aluminum
 Tool Fitting 6 mm Hex
 Hub Compatibility T/A 15 x 100 | T/A 15 x 110
 Recommended Torque 10Nm
Forks Compatibility List:
X-Rock Shox (148mm)
  • Rock Shox
    • SID
        • SL
          • Ultimate, Brain , Select +, Select (2021)
        • Ultimate (2021)
        • Select / Select + (2021)
        • WC, XX, RCT3, RLT, RL (2012-2015)
    • RS-1 (2015-)
    • Reba RLT, RL (2012-2015)
    • Pike DJ, RC, RCT3 (2014-2015)
    • Revelation WC, XX, RCT3, RLT, RL (2014-2015)
  • Santa Cruz
      • Stigmata
X-Fox Boost (155mm)
  • Fox Float
    • 32
        • Step-Cast 15x110mm (2017-2021)
        • 15x110mm (2016)
    • 34
        • 15x110mm (2016-2021)
  • NOT COMPATIBLE WITH THE 2021
    • Fox Float 36
    • Fox Float 38
X-Rock Shox Boost (158mm)
  • Rock Shox
      • SID RL, RLC, WC, Brain Boost (2016-2020)
      • Reba RL Boost (2016-2020)
      • Lyric RC, RC2, RCT3 Boost (2016-2020)
    • 2021 SID, SID SL (Ultimate, Brain Select=, and Select)
    • RS-1
      • For Compatible models check RockShox (148mm)
