Carbon-Ti X-Lock EVO 12 mm Front Thru Axle
$79.00
Article number: 008-02-05
True to the quality we have come to expect from Carbon-Ti, these thru axles are excellently stiff, with variable thickness. There is a 6mm hex fitting for safe and secure closing(hex key not provided), as well as beautifully laser etched graphics.
These axles are available in several of Carbon-Ti's beautiful anodized hues.
All Carbon-Ti products are proudly designed and manufactured in Italy.
Model Interface Length Pitch Thread Length Weight
X-12 Road Tapered 117 mm 12 x 1.0 mm 14 mm ~22g
120 mm Road Flat 120 mm 12 x 1.5 mm 13 mm ~22g
125 mm Road Flat 125 mm 12 x 1.5 mm 13 mm ~24g
122 mm Road Flat 122 mm 12 x 1.75 mm 10.5 mm ~24g
 Material 7075 Aluminum
 Tool Fitting 6 mm Hex
 Hub Compatibility T/A 12 x 100
 Recommended Torque 10Nm
Forks Compatibility List:
X-Lock 12x1.0 X-12 (117mm)
  • Specialized
      • Aethos (2021)
      • Crux S-Works (2019-2021)
      • Crux Disc (2019-2021)
      • Tarmac SL7 & SL6 S-Works Disc (2019-2021)
      • Tarmac SL7 & SL6 Pro, Expert, Comp Disc (2019-2021)
      • Venge S-Works Disc (2019-2020)
      • Venge Pro, Expert, Comp Disc (2019-2020)
X-Lock 120 mm Road
  • Bianchi
      • Aria (2020-2021)
      • Specialissima (2021)
      • XR4 Disc (2021)
  • Cinelli
      • Nemo Tig Gravel (2021)
      • Pressure (2021)
  • ENVE
      • Carbon Disc Fork
  • Pinarello
      • Disc (2019)
  • Scott
      • Addict Gravel (2020-2021)
      • Foil Disc (2018-2019)
  • Ridley
      • Noah
X-Lock 125 mm Road
  • Bianchi
      • Zolder Pro (2019)
  • Cannondale
      • Synapse Disc (2018)
  • Parlee
      • Altum Disc  (2018-)
      • Chebacco  (2018-)
      • Z-Zero Disc/XD  (2018-)
      • TTiR Disc  (2018-)
  • Scott
      • Addict (2020-2021)
X-Lock 122 mm Road
  • Trek
      • Emonda Disc (2019-2021)
      • Madone Disc (2019-2021)
