Carbon-Ti X-Lock 15 mm Front Thru Axle
UPC:
Default Tax Class
$75.00
With an impressive repertoire of expertly machined components fit for even the most elite builds, Carbon-Ti is quickly making a name for themselves as a reputable manufacturer. Born from Italian special alloy and carbon fiber manufacturer LLS Titanium, Carbon-Ti is able to draw on an immense wealth of knowledge in order to produce quality parts fit for nearly every modern mountain bike.
With industry standards shifting from quick releases to though axles, having high quality aftermarket options to precision tune your build becomes a welcome luxury. Luckily, Carbon-Ti has produced some incredibly handsome front thru axles designed to work with current standards used by various manufacturers. Ideal for cyclists looking to shed grams while also maintaining a minimalist aesthetic, the Carbon-Ti X-Lock front thru axle is sure to find a home on many elite builds.
The Carbon-Ti X-Lock Front thru axle is proudly made in Italy.
Check out our blog for better info about which thru axle to use
ModelHub CompatibilityInterfaceLengthThread PitchThread LengthWeight
15 mm RoadTA 15 x 100 RoadFlat125 mm15 x 1.5 mm10 mm23g
DTTA 15 x 100Flat144 mm15 x 1.5 mm17 mm35g
FoxTA 15 x 100Flat146 mm14 x 1.5 mm11 mm34g
Fox BoostTA 15 x 110 BoostFlat156 mm14 x 1.5 mm14 mm36g
Rock ShoxTA 15 x 100Flat147 mm15 x 1.5 mm10 mm36g
Rock Shox BoostTA 15 x 110 BoostFlat156 mm15 x 1.5 mm12 mm36g
Material7075 aluminum
Tool Fitting5mm Hex
Recommended Torque10Nm
Front Thru Axle
Sub-category:
Boost Front Thru Axle
Interface:
Flat
Style:
Road Disc
Style:
Boost
Style:
Mountain
Diameter:
TA 15 x 100 Road
Diameter:
TA 15 x 110 Boost
Fits:
14 x 1.5 mm
Fits:
15 x 1.5 mm
Acid Green
Blue
Gold
Red
Aluminum
