Carbon-Ti X-Lock 15 mm Front Thru Axle
Article number: | 008-04-01 |
Availability: | In stock (4) |
With industry standards shifting from quick releases to though axles, having high quality aftermarket options to precision tune your build becomes a welcome luxury. Luckily, Carbon-Ti has produced some incredibly handsome front thru axles designed to work with current standards used by various manufacturers. Ideal for cyclists looking to shed grams while also maintaining a minimalist aesthetic, the Carbon-Ti X-Lock front thru axle is sure to find a home on many elite builds.
All Carbon-Ti products are proudly designed and manufactured in Italy.
Model | Fits | Length | Pitch | Thread Length | Weight |
15 mm Road | T/A 15 x 100 | 125 mm | 15 x 1.5 mm | 10 mm | ~23g |
DT | T/A 15 x 100 | 144 mm | 15 x 1.5 mm | 17 mm | ~35g |
Fox | T/A 15 x 100 | 146 mm | 14 x 1.5 mm | 11 mm | ~34g |
Fox Boost | T/A 15 x 110 | 156 mm | 14 x 1.5 mm | 14 mm | ~36g |
Rock Shox | T/A 15 x 100 | 147 mm | 15 x 1.5 mm | 10 mm | ~36g |
Rock Shox Boost | T/A 15 x 110 | 156 mm | 15 x 1.5 mm | 12 mm | ~36g |
Material | 7075 Aluminum | ||||
Tool Fitting | 5 mm Hex | ||||
Interface | Flat | ||||
Recommended Torque | 10Nm |
