With an impressive repertoire of expertly machined components fit for even the most elite builds, Carbon-Ti is quickly making a name for themselves as a reputable manufacturer. Born from Italian special alloy and carbon fiber manufacturer LLS Titanium, Carbon-Ti is able to draw on an immense wealth of knowledge in order to produce quality parts fit for nearly every modern mountain bike.
With industry standards shifting from quick releases to though axles, having high quality aftermarket options to precision tune your build becomes a welcome luxury. Luckily, Carbon-Ti has produced some incredibly handsome front thru axles designed to work with current standards used by various manufacturers. Ideal for cyclists looking to shed grams while also maintaining a minimalist aesthetic, the Carbon-Ti X-Lock front thru axle is sure to find a home on many elite builds.
The Carbon-Ti X-Lock Front thru axle is proudly made in Italy.
Check out our blog for better info about which thru axle to use | ||||||
Model | Hub Compatibility | Interface | Length | Thread Pitch | Thread Length | Weight |
X-12 Road | TA 12 x 100 | Tapered | 117 mm | 12 x 1.0 mm | 14 mm | 26g |
12 x 119 mm Road | TA 12 x 100 | Flat | 119 mm | 12 x 1.5 mm | 12 mm | 23g |
12 x 123 mm Road | TA 12 x 100 | Flat | 123 mm | 12 x 1.75 mm | 12 mm | 25g |
12 x 125 mm Road | TA 12 x 100 | Flat | 125 mm | 12 x 1.5 mm | 12 mm | 24g |
Material | 7075 aluminum | |||||
Tool Fitting | 5mm Hex | |||||
Recommended Torque | 10Nm |
