Carbon-Ti X-Hub SP Disc Rear Hub
$410.00
Update - Carbon-Ti X-Hub SP Rear hubs are now equipped with a quick-engaging 56 tooth ratchet ring, with four steel pawls that each simultaneously engage three ratchet teeth. Additionally, the axle preload adjustment ring has been reshaped for easier adjustment, and is now equipped with a locking set screw.
Since 2005, Carbon-Ti has been making a name for themselves in the cycling community by offering performance tuned components designed with the discerning cyclist in mind. As an offshoot of exotic materials manufacturer, LLS Titanium, Carbon-Ti draws from many years of material science experience in order to create components of the highest quality.
The Straight Pull Disc X-hub is an excellent testament to Carbon-Ti’s attention to aesthetics and performance. Uniquely machined from 7075 T-6 aluminum, the Straight Pull X-Hub is both lightweight and resilient, two huge factors for the gram conscious rider who consistently finds themselves on terrain that tests the limits of their skills and componentry. Equipped with an ingenious toolless bearing preload adjuster, the X-Hub can be perfectly dialed in on the fly, and ensures that any adjustments stay where you want them. By simply turning the knurled endcap, any bearing micro adjustment is possible within seconds. Easy to overhaul and built to last, the X-Hub additionally utilizes the tried-and-true 4 pawl freehub body design, giving each rider the peace of mind knowing their components won’t fail in the middle of a long ride.
The Carbon-Ti Sl Straight Pull X-Hub is proudly designed and manufactured in Italy.
Weight189 grams
Material7075 T6 aluminum
Spacing12 x 142mm
CompatibilityShimano / Sram 10/11 speed
