Carbon-Ti X-Hub SP Centerlock Front Disc Hub
$195.00
As an offshoot of exoctic materials manufacturer, LLS Titanium, Italy based Carbon-Ti draws from decades of material science and design experience to bring the cycling community an array of quality components. Since 2005, Carbon-Ti has produced uniquely handsome parts that make no compromises in either weight or performance.
The Straight Pull X-Hub from Carbon-Ti is unquestionably an excellent example of their design and machining prowess. Featuring an ingenious tool-free bearing preload adjustment system, the X-Hub can be adjusted to perfection in seconds by simply turning the clever knurled cone. Expertly machined from 7075 T-6 aluminum, the SP X-Hub is both lightweight and robust, two huge necessities for gram conscious riders who often find themselves pushing their components to the limits. Seamlessly paired with the SP X-Hub Rear Disc Hub, each hub from Carbon-Ti is an ideal way to add a dash of exotic Italian flair while simultaneously ensuring the longevity of your next wheelset.
Weight92 grams
Bearing Sizes6803 (2)
Axle Outer Diameter17mm
Material7075 T6 aluminum
Brake Rotor CompatibilityCenterlock
w/adapter - 6-bolt
Front Disc Brake Hubs
Fits:
24h
Style:
Road Disc
Style:
Mountain
Diameter:
TA 12 x 100
