Carbon-Ti X-Hub SP Boost Front Disc Hub
$209.00
As an offshoot of exotic materials manufacturer LLS Titanium, Italy based Carbon-Ti draws from decades of material science and design experience to bring the cycling community an array of quality components. Since 2005, Carbon-Ti has produced uniquely handsome parts that make no compromises in either weight or performance.
The new Carbon-Ti Straight Pull Boost X-Hubs represent the continued refinement of Carbon-Ti cycling products.  Carbon-Ti manufactures this hub from a solid block of Al7075-T6 aluminum, which is meticulously CNC machined to achieve an incredibly light weight while maintaining an impressive stiffness-to-weight ratio.  The 17mm axle, also made of Al7075-T6 aluminum, has a variable wall thickness to keep the weight low while retaining strength in higher stress areas.  This axle rides on two high-quality sealed bearings, with externally adjustable preload courtesy of Carbon-Ti's Bearing Preload System Tuning (BPS).  This preload system, which consists of a machined dial and grub screw, makes hub adjustments quick and easy.  These 110mm boost hubs come in at a very impressive 95 grams and are 100% made in Italy.  With the combination of its light weight and robust build, Carbon-Ti's X-Hub SP Boost hubs should be at the top of the list for gram-conscious riders who push their components to the limit.
Weight95 grams
Axle Standard15 x 110mm Boost
Bearing Sizes6803 (2)
Axle Outer Diameter17mm
Material7075 T6 aluminum
Brake Rotor Compatibility6-bolt ISO
Available Drilling28 hole
Wheel Building Dimensions
Left Flange Diameter47.5 mm
Right Flange Diameter43.5 mm
Center to Flange Left37.5 mm
Center to Flange Right28.5 mm
Spoke Hole Offset2 mm
Front Disc Brake Hubs
Blue
Fits:
24h
Fits:
28h
Fits:
32h
Diameter:
TA 15x110 Boost
Style:
Mountain
