Carbon-Ti X-Hub SP Boost Front Disc Hub
| Article number: | 008-05-02 |
Carbon-Ti manufactures this hub from a solid block of Al7075-T6 aluminum, which is meticulously CNC machined to achieve an incredibly light weight while maintaining an impressive stiffness-to-weight ratio. The 17mm axle, also made of Al7075-T6 aluminum, has a variable wall thickness to keep the weight low while retaining strength in higher stress areas. This axle rides on two high-quality sealed bearings, with externally adjustable preload courtesy of Carbon-Ti's Bearing Preload System Tuning (BPS). This preload system, which consists of a machined dial and grub screw, makes hub adjustments quick and easy. These 110mm boost hubs come in at a very impressive 95 grams and are 100% made in Italy. With the combination of its light weight and robust build, Carbon-Ti's X-Hub SP Boost hubs should be at the top of the list for gram-conscious riders who push their components to the limit.
WHEEL BUILDING
Trust a skilled wheelbuilder for your Carbon-Ti built wheels. Contact us for custom wheels, we offer expert service and rim / spoke advice.
| X-Hub | |
| Weight | ~92g |
| Spoke Holes | 24h / 28h |
| Axle Standard | 15 x 110 mm |
| Bearing Size | 6803 - (2) |
| Brake Interface | 6-bolt |
| --Wheel Building Dimensions-- | ||
| LEFT | RIGHT | |
| Flange Diameter | 47.5 mm | 43.5 mm |
| Center to Flange | 37.5 mm | 28.5 mm |
| Spoke Hole Offset | 2.0 mm | |
| Spoke Hole Diameter | 2.5 mm | |
