Carbon-Ti X-Hub Freehub
$145.00 - $175.00
Perfect for converting your X-Hub to use a SRAM, Shimano or Campagnolo 9, 10, 11, or 12 speed cassette, all freehubs comes pre-assembled with bearings, lip seal, pawls and springs. Compatible with all of their 17mm axle hubs made after 2012, this conversion gives you more choice in drivetrains and virtually limitless gearing options.
Like all Carbon-Ti products this freehub is proudly designed and manufactured in Italy.
The freehubs are only compatible with X-Hub SL and Straight Pull Disc or Road hubs with 56t engagement hubs sold after September 2017. The 28t version is used with hubs sold prior to September 2017
Weight
SRAM XD~49 grams
SRAM XDR*49 grams
Shimano 10/11spd*53 grams
Campagnolo52 grams
Micro Spline**61 grams
Compatibility2017 and newer X-Hubs (17mm Axles)
Drivetrain Compatibility10, 11, & 12 Speed
Cassette CompatibilityShimano 10/11spd
SRAM XD
Campagnolo
SRAM XD
Shimano Micro Spline
* - Weight will change slightly if 1.8mm spacer is used behind cassette
** - Micro Spline freehubs come with a replacement axle for all hubs manufactured prior to March 2020
Freehub
