Carbon-Ti X-Hub 56t Freehub Body
$155.00
* Unit price: $155.00 /
Article number: 008-05-04
Perfect for converting your X-Hub to use a SRAM, Shimano or Campagnolo 9, 10, 11, or 12 speed cassette, all freehubs comes pre-assembled with bearings, lip seal, pawls and springs. Compatible with all of their 17mm axle hubs made after September 2017, this conversion gives you more choice in drivetrains and virtually limitless gearing options.
Like all Carbon-Ti products this freehub is proudly designed and manufactured in Italy.
The freehubs are only compatible with X-Hub SL and Straight Pull Disc or Road hubs with 56t engagement hubs sold after September 2017. The 28t version is used with hubs sold prior to September 2017.
 Drivetrain Compatibility 10, 11, & 12 Speed, Shimano 10/11spd, SRAM XD
 Cassette Compatibility Campagnolo, SRAM XD, Shimano Micro Spline
 Weight
 SRAM XD ~49g
 SRAM XDR* ~49g
 Shimano 10/11spd* ~53g
 Campagnolo ~52g
 Micro Spline** ~61g
* - Weight will change slightly if 1.8mm spacer is used behind cassette
** - Micro Spline freehubs come with a replacement axle for all hubs manufactured prior to March 2020
