Carbon-Ti's line of Sram AXS 12-speed compatible chainrings are thicker and stiffer than their non-AXS counterparts in order to keep up with the demands of Sram's flagship electronic shifting system. These chainrings offer performance on par with Sram's stock chainrings while shedding a good deal of weight, all in an incredibly attractive package. Carbon-Ti bonds their specially-profiled 7075 aluminum teeth with a high-gloss carbon center. The inner carbon surface of the larger rings is additionally shaped with ramps, and titanium shift pins are added for the best possible shift performance.
X-AXS 110 BCD 5-bolt chainrings are compatible with standard compact cranksets, allowing Sram AXS 12-speed drivetrain compatibility with non-AXS cranks. These chainrings are designed to be used in specific combinations (50/37, 48/35, 46/33) for optimal shift performance and gear ratio transition. Other combinations are not recommended.
Carbon-Ti premium chainrings are 100% made in Italy.
Weight, 33t | 31 grams |
Weight, 35t | 32 grams |
Weight, 37t | 37 grams |
Weight, 46t | 77 grams |
Weight, 48t | 92 grams |
Weight, 50T | 99 grams |
BCD | 110 mm, 5-bolt |
Crankset Compatibility | standard compact 110 BCD (non-hidden bolt) |
Drivetrain Compatibility | Sram AXS 12-speed |
Material | 7075 aluminum carbon fiber grade 5 titanium |
