Carbon-Ti X-CarboRing EVO X-AXS 110 BCD Carbon Chainring
$179.00
Article number: 008-06-01
Carbon-Ti's SRAM AXS 12-speed compatible chainrings are engineered with enhanced thickness and stiffness to meet the demands of SRAM's premium electronic shifting system. These chainrings not only match SRAM's stock options in performance but also significantly reduce weight, all wrapped in an exceptionally attractive design. The secret lies in the combination of specially-profiled 7075 aluminum teeth with a high-gloss carbon center, complemented by inner carbon ramps and titanium shift pins for flawless shifting performance. Available in both 4-bolt and 5-bolt configurations, the X-AXS 110 BCD chainrings are designed for use with SRAM AXS 12-speed drivetrains, with specific combinations (50/37, 48/35, 46/33) ensuring optimal shift performance and seamless gear ratio transitions. These chainrings are the top choice for cyclists seeking both precision and style in their components.
 Material Carbon (body), AL7075-T6 Aluminum (teeth), Titanium (pins)
 BCD 110 BCD - 4-bolt
 Drivetrain Compatibility SRAM AXS 12spd
 Optimal Combinations 50t / 37t | 48t / 35t | 46t / 33t
 Crank Compatibility SRAM Force / Red eTap AXS 12spd
  SRM Origin
Weight 50 tooth 48 tooth 46 tooth 37 tooth 35 tooth 33 tooth
4-bolt ~98g ~93g ~89g ~37g ~36g ~35g
5-bolt ~95g ~90g ~86g ~35g ~34g ~33g
