Carbon-Ti X-CarboRing EVO X-AXS 107 BCD Carbon Chainring
$179.00
Article number: 008-06-01
Carbon-Ti's SRAM AXS 12-speed compatible chainrings stand out for their enhanced thickness and stiffness, tailored to meet the demands of SRAM's premium electronic shifting system. These chainrings not only match the performance of SRAM's stock options but also shed considerable weight while offering an exceptionally attractive design. Carbon-Ti achieves this by combining specially-profiled 7075 aluminum teeth with a high-gloss carbon center and incorporating inner carbon ramps and titanium shift pins for optimal shifting performance. The X-AXS 107 BCD 4-bolt chainrings are designed for use with SRAM AXS 12-speed drivetrains, available in specific combinations (50/37, 48/35, 46/33) to ensure ideal shift performance and gear ratio transitions, making them a top choice for cyclists seeking precision and style.
 Material Carbon (body), AL7075-T6 Aluminum (teeth), Titanium (pins)
 BCD 4-bolt - 107 BCD
 Drivetrain Compatibility SRAM AXS 12spd
 Optimal Combinations 50t / 37t | 48t / 35t | 46t / 33t
 Crank Compatibility SRAM Force / Red eTap AXS 12spd
Weight 50 tooth 48 tooth 46 tooth 37 tooth 35 tooth 33 tooth
4-bolt ~101g ~98g ~94g ~41g ~32g ~30g
