$225.00
* Unit price: $225.00 /
Article number: 007-01-04
Carbon-Ti's "EVO" outer chainrings, with thicker carbon plates, enhance stiffness for precise CNC machining. Redesigned titanium pins ensure swift, accurate shifts compatible with electronic and mechanical derailleurs. Weighing low yet durable, they feature tooth counts from 50 to 54, optimizing pedal stroke efficiency and power output, reflecting Carbon-Ti's commitment to cutting-edge engineering.
The X-CarboRing EVO 5-Bolt chainrings ensure seamless compatibility with Shimano 11 & 12-speed, SRAM 11-speed, and Campagnolo 11 & 12-speed drivetrains. The 53 / 39 chainrings are the only chainrings you can choose between 110 BCD or 130 BCD. Not compatible with SRAM AXS 12-speed; opt for X-AXS 5-bolt 110 BCD. Make the right choice for your drivetrain with Carbon-Ti.
 Material Carbon (body), AL7075-T6 Aluminum (teeth), Titanium (pins)
 BCD 5-bolt - 110 BCD or 130 BCD
 Drivetrain   Compatibility Shimano 11 / 12spd, SRAM 11spd, and Campagnolo 11 / 12spd
Not Compatible with SRAM AXS 12 spd groups
 Optimal   Combinations 54t / 40t | 53t / 39t | 52t / 36t | 50t / 34t
 Crank   Compatibility 5-bolt 110 & 130 BCD Cranksets
Weight
110 BCD 54 tooth 53 tooth 52 tooth 50 tooth
  ~114g ~108g ~104g ~93g
  40 tooth 39 tooth 36 tooth 34 tooth
  ~47g ~36g ~33g ~28g
130 BCD 53 tooth 39 tooth
  ~115g ~45g
