Italian parts manufacturer Carbon-Ti is a relatively new company to the Fair Wheel family, however their extensive repertoire of quality performance tuned components prove they know exactly what they’re doing. As an offshoot of LLS titanium, an older and highly experienced special alloy and carbon manufacturer, Carbon-Ti is able to draw upon a vast wealth of engineering and material science know-how to produce some truly impressive components.
The X-Ring from Carbon-Ti is an exquisite example of their design expertise in motion. Featuring a carbon fiber inner ring, bonded to a 7075 T6 aluminum tooth pattern, the X-Ring is a unique way to drop grams on your next build, while simultaneously adding a touch of high-end class. By reducing weight from your drivetrain, the amount of energy required for a revolution of the crank is decreased, therefore optimizing pedal stroke and increasing power. Additionally equipped with special carbon fiber shift ramps, the Carbon-Ti X-Ring is designed to shift well under pressure, while remaining as lightweight as possible.
Material | carbon aluminum |
BCD | 110 130 |
Drivetrain Compatibility | 10 / 11 speed road |
Weights | |
34 Tooth | 27 grams |
36 Tooth | 32 grams |
50 Tooth | 73 grams |
52 Tooth | 78 grams |
39 Tooth | 35 grams |
53 Tooth | 85 grams |
