Carbon-Ti X-CarboCam 110 BCD 4-Arm Oval Chainrings
$198.00
To maximize pedal stroke efficiency and power, Carbon-Ti presents their X-CarboCam asymmetric chainrings.  The ovalized ring shape allows optimization of power and efficiency by minimizing the effect of “dead spots” in the pedal stroke.  Weight is kept extremely low (The 50 tooth weighs in at a mere 82 grams while the 52 tooth is only 86 grams) using a mixture of carbon (inner body), AL7075-T6 aluminum (teeth), and titanium (shift pins).  By utilizing these varied materials, Carbon-Ti is able to achieve both a lightweight and highly functional ring; the carbon body keeps weights low while the aluminum and titanium parts aid in shift quality and durability.  These chainrings feature a 110 BCD 4-bolt pattern and are 100% made in Italy (110 BCD 5-Bolt version available here).  The Carbon-Ti CarboCam rings are designed to be paired only with their aluminum siblings, the Carbon-Ti X-RoadCam rings (available here from the drop-down menu).  The designated combinations are 50/36 or 52/38; mismatching ring sizes or mating these with other manufacturer's inner rings will compromise the shifting performance.
The 50 and 52 tooth outer chainrings are designed to fit Shimano's 110 BCD 4-bolt asymmetric cranks, in two versions: one to fit Dura-Ace FC-R9000 and Ultegra FC-6800 cranksets, and the other to fit the newer Dura Ace FC-R9100 and Ultegra FC-R8000 cranksets. The Roadcam inner chainrings are cross-compatible between these two generations of cranksets.
The Carbon-Ti 36 and 38 tooth X-RoadCam rings are manufactured entirely from AL7075-T6 aluminum and weigh a scant 31 and 41 grams respectively.  They feature the same asymmetrical construction as their big-ring partners, thus offering the same optimization of power and efficiency. Like all Carbon-Ti products, they are made 100% in Italy.
Material (50 and 52 tooth)Carbon (body), aluminum (teeth), titanium (shift pins)
Material (36 and 38 tooth)AL7075-T6 Aluminum
BCD4-Arm/Bolt, 110 BCD
Chain Compatibility11/12 speed
Weights
52 Tooth86 grams
50 Tooth82 grams
38 Tooth41 grams
36 Tooth31 grams
Individual Chainrings
Brand:
Carbon-Ti
Size:
36T
Size:
38T
Size:
50T
Size:
52T
Fits:
110 BCD, 4-Arm
Style:
Oval
Carbon
Aluminum
Titanium
